Saltar al contenido principal
La única version con Wi-Fi del Apple iPad 6, lanzada en marzo de 2018. Disponible con 32 y 128 GB de almacenamiento. Dispone de una pantalla Retina de 9.7 pulgadas y de un chip de fusión de 64 bits A10.
Preguntas 20 Ver todo
Part of screen not touch responsive after display replacement
Thank you for your guide. I’m almost finished but before closing the screen to the frame I’m testing whether the touch works. But on the unlock screen all numbers but 1, 2 and 3 work. What could cause this problem? I have installed the kapton tape on the replacement screen.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Did you unhook the battery before you took off the screen and reinstalled it? Unhook the battery and disconnect the screen connector and get a magnifying glass and see if the pins were damaged. If they are ok on both connectors than take a qtip with a little alcohol and clean the connectors then brush them off with a soft brush. Reconnect and try it again
Fue útil esta respuesta?
Puntuación 2
Hey Allan Barr,
Thx for your comment, I also had small part of the touchscreen that did not responded.
Followed your steps and it’s working 100% now.
Thank you for your contribution!
Grtz
Puntuación 0
Añadir tu respuesta
Michel Braamhaar estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 623
