Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Version más pequeña del iPad Pro original. Publicado el 31 de Marzo de 2016. Cuenta con una pantalla 9.7", procesador A9X y acciones de almacenamiento de 32/128/256 GB. Disponible en plata, gris espacio, oro y oro rosa.
System shuts down randomly after battery replacement
So this is a weird issue. I recently replaced my iPad Pro 9.7’s battery with one from iFixit. The kit was perfect, and I was able to do the repair with the tools provided. However, after this, any time I attempt to use a graphically intensive application (but not CPU intensive application) and only when the smart keyboard is connected, the iPad will shut down, and become unusable until disassembled, and the battery disconnected for several seconds and reassembled. I tried a software restore from DFU mode, but to no avail. Does anyone have any ideas?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
2 comentarios:
Have you by any chance tried re-installing the old battery to verify everything works correctly?
- de
I haven’t yet, but that’s a good idea.
@martmart
- de
Agregar un comentario
1 Respuesta
I too changed my battery
Update (11/06/2020)
I have now tried 3 OEM batteries including reinstalling the existing one and all cause the iPad to go into a restart loop I think iOS v14 devices are firmware locked as all show 100mAh on Coconut Plus which probably causes the restart loops. Even completed hard reset and total factory reset to see if it was something else causing it however still stuck in restart loop even when charging. I have accepted defeat and paid £106 to Apple
Fue útil esta respuesta?
Puntuación 0
1 comentario:
I think I remember reading that every iPad post 5th Generation and post iPhone 5SE will be firmware locked so to prevent 3rd party change out!
- de
Añadir tu respuesta
Tyler Barney estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 39
Todo El Tiempo: 800
