Hvac blend door actuator replacement
Where is the blend door actuator located
Es esta una buena pregunta?
Im not sure on all years but on my 07 escape it is located in the back left (drivers side) quarter panel. To access it ,you need to pull the plastic cover pieces on the inside of your rear hatch. They are push pins so pull carefully with your hands working it from the edges. There are some very good videos on you tube specifically for this Good Luck
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 24
Todo El Tiempo: 174
