Saltar al contenido principal
El Mac Pro de principios de 2009, también conocido como Mac Pro 4,1, introdujo la arquitectura Nehalem de Intel en la línea de computadoras de escritorio profesionales de Apple en marzo de 2009. El Mac Pro 5,1 usó el mismo diseño interior pero recibió más actualizaciones de CPU en 2010 y
SATA Connection Power Question
How much power is generated from the SATA connections on the 2009 Mac Pro? I want to see if I can power a pcie card.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Per the spec you have three volatages
  • 3.3 V - Orange wires
  • 5.0 V - Red Wires
  • 12 V - Yellow Wires
  • Ground - Black Wires
4.5 Amps max (54 Watts) per logic board/power supply connection.
I personally don’t like pressing a sustained load more than 3 Amps per drop. I also like to disperse the load across different rail lines if the power supply offers it.
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
Hi Dan,
Thanks for your response. I’m trying to figure out where I can get power for this card. The specs say the theoretical maximum power consumption of the card is 40w/136.5 BTU. Would you recommend that I possibly try to find a secondary auxiliary source as opposed to trying to use the SATA connection?
- de
First, Are you sure you have the needed drivers for it? Many of the newer cards won't work in this older Mac Pro. The spec sheet max power consumption is the worse case. Are you expecting to push the system to the wall? I hope not!
What are you planing on using your system for?
- de
Añadir tu respuesta
Shelton Morgan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 177
