A BIG DEFROSTING TROUBLE of SAMSUNG RR35H66107F
Hello,
My fridge works for 5 to 10 days correctly, the fridge set temperature at (3°) and the thermometer temperature inside it indicates the same set temperature of (3°). The compressor works and stops and the room-fan as well. But the problem begins when the thermometer temperature inside fridge-room starts rising without any indication in the led-screen which remains fixed at (3°), this process occurs for about one to two days. Then the led-screen temperature indication start winking at this moment the thermometer indicate a fridge-room temperature of about (14°) and the compressor and the fan do not stops working. I know why! Because ice builds in evaporator.
I don’t know how to fix this since this model comes without defrost heater element!
I checked all sensors evaporator, room and ambient sensors are okay. The fan works as well and has been replaced.
I read 9.35Volts when working at “power cool” mode when the fridge is about to starting after a long rest time.
The cards look good!
I don’t know how to end with this problem?
A small description of the problem in this video : https://www.youtube.com/watch?v=NsUiwwel...
Waiting for your answer
Es esta una buena pregunta?
