Sd card error on pocophone f1
The phone sometimes having problem with the sd card when access the file in it or use the storage, which make the sd card become error. But, when i connect the sd card using adapter to the pc, the file is still there. I am using SDXC memory card. There's an option whether the user can set the sd card as phone storage or portable storage. I had set the memory card as phone storage and the format it…. Is it the cause of the error of the memory card….its been 3 times already the error happens.
Es esta una buena pregunta?
If you do this - never ever remove the card. If you do the above, your card becomes *totally* part of your phone.
If you want to remove SDCARD, copy and paste - choose PORTABLE storage.
- de bmx2019
