Why is my machine getting an OE error between each cycle
Hi, my LG front load washer/dryer won’t complete a full wash. It stops with an error message ‘OE’ at the end of the washing cycle, I then turn it off and change it to rinse and spin only and it rinses but then same thing happens at the end of the rinse cycle and so on. Obviously something wrong with the drainage, no kinked hose, clean filter and the pump is working because it will drain the water away once turned off and the cycle changed manually to the next step. Is this an issue with the computer….?
Es esta una buena pregunta?
2 comentarios
I’m having the same problem. I’ve replaced the drain pump, inspected all the lines, and replace a couple of valves already, but nothing has worked.
I see this happened to you almost 2 years ago. Did you figure out what was causing it?
Hopefully this will help me with my issue.
Thank you
- de kj-html
Did anyone fix this? I’ve the exact same issue.
The machine drains fine mid cycle after the wash and first rinse phases. But doesn’t drain on the final rinse and spin.
- de Pauly G
