Replacement display (Replace A1989 -> A1706)
I am using A1989. Is it possible to replace it with a 1708 display?
Is it impossible because I have a T2 chip?
I want to use a new A1706 display
Es esta una buena pregunta?
What you want and what works are very different!
No! You can’t use the older display used in either the two or four port 2016/17 models in the newer system. They are not compatible!
Here is the correct part for your system:
Presently there is no used displays available which would be cheaper.
Fue útil esta respuesta?
how about A1707 2 port with A1706 4 port?
The A1706 system is a 13" and the A1707 is a 15" very different sizes!
And BTW both are four port systems.
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 789
