Saltar al contenido principal
Modelo A1001 o A1025 / procesador 667, 800, 867 o 1.0 GHz G4
Preguntas 50 Ver todo
Problems connecting with 802.11b Airport card?
In the interest of extending the life of my PowerBook G4, I installed an 802.11b airport card. My issue has been accessing the existing wireless network, which is NetGear 54Mps 802.11b/g. It won’t see the network, and when I tell the preferences what network I am looking for it doesn’t go through. I figure the problem lies with the differences of the protocols. Does anyone have any insight into this issue?
Thank you for your help
Richard
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Your problem may lie in the security protocol of the network. What Encryption type are you using? WEP? WPA? WPA2 Personal? Another thing, if your router has this option, make sure your router is set to "compatibility" or "legacy" mode, and not set to see just wireless G.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
I ended up setting the router to WEP 64 bit Hex. Took one of the generated passwords, plugged it in to the laptop and that worked. After running around and resetting all of the other machines and phones in the house everything worked out fine. Thank you for your help and advise.
Richard
- de
No problem, glad I was able to help.
- de
Añadir tu respuesta
rpeal38 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 2,192
