Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Samsung Galaxy Amp 2 se lanzó en 2016 con el número de modelo SM-J120AZ UD. Es un smartphone con sistema operativo Android.
Broken LCD screen, battery problems, how to fix it?
My Samsung Galaxy Amp 2 has multiple issues right now. One is a cracked LCD screen, not the glass of the phone. The cracks were seen invisibly black, was seen in this photo because I think the glass of the phone is broken. It was the LCD or the LED screen.
Imagen
Then I tried to jump-start my phone’s battery using a 9V battery
Imagen
into my removable battery and my phone’s battery was working, with full revival energy in the battery.
Once I charged my phone with a revived battery, something was wrong. It doesn’t have the screen on or the phone wasn’t charging. It also doesn’t vibrate and the charging box doesn’t heat. When I did these steps below, it doesn’t work.
  1. Charging my phone
  2. Removing my battery and putting it back again
  3. Pressing any button with the power button
At least an hour after charging, the phone’s removable battery drained because the screen wasn’t on. And my phone wasn’t charging either. I jumped start my phone using the 1st and the 3rd sockets rather than 1st and 4th as seen in the WikiHow image compared to my phone’s image:
Imagen
Imagen
(Sorry for the focus, red means positive while black or blue is negative)
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
If that 9V battery was able to charge your cellphone battery, odds are you fried it. Lithium batteries need to be pulse charged and at a proper voltage so that 9V battery was more than double what it can handle. It may have worked temporarily but you most likely damaged that cellphone battery. Use a multimeter, set it to DC volts and touch the corresponding contacts with the probes. It should read anywhere between 3.6v and like 4.4v
Fue útil esta respuesta?
Puntuación 0
1 comentario:
I don't have a multimeter, and my battery's voltage went down when I charge this phone, and my phone doesn't turn on because the screen wasn't lit.
- de
Añadir tu respuesta
Evan Lei estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 21
Todo El Tiempo: 762
