Remove Display From MBP
Hi,
I have a MBP that recently had a bit of an accident and the display died.
I don´t want to replace the display, but rather use the MBP to replace an old Mac Mini I have.
The problem is that with the display broken I can only access it through the HDMI cable when I mirror the MMBP´s display. But, I have a couple of partitions, one Linux and one Windows that I need to access every once in a while and it’s complicated to do it.
Basically, I would rather do without the original display present, so the question is, what would happen if I remove the display completely, will I be able to use the HDMI monitor from boot in order to access the other partitions ??
Will it be selected as default when the original display is not present ??
Thanks
Manuel
Es esta una buena pregunta?
