I have a strange problem with my screen
Hello, I have the same issue on my MacBook Air 2019, when I shut down it this is what I get (see images below), but the issue disappear when I login safe mode. What should I do?
Es esta una buena pregunta?
Sadly your display assembly if failing. You’ll need a new display assembly
Your systems graphics services (Intel UHD Graphics 617) runs in two modes. When it’s in Safe mode its running in the low res 1680 by 1050 and once the drivers are loaded from within the OS it will jump to 2560 by 1600.
Fue útil esta respuesta?
Thank you for your answer, fortunately I’m still under warranty.
@itsalenash - Don't forget to accept the answer!
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 206
