Saltar al contenido principal
El láser TBK 958c es una herramienta multifunción que puede grabar vidrio o se usa para quitar el adhesivo que sujeta el vidrio de la placa posterior que se usa en los iPhone.
TBK 958A missing iPhone 8 file. How to find...
I got my laser back glass removal machine to make a successful run the first time around on a test iPhone 8 cracked back glass and it worked fine.
But the second time around when I try to select the iPhone 8 file nothing appears. Is there any way I can recover this file somehow?
Does my TBK 958c have a software issue?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 5
5 comentarios:
Idem - stesso problema iPhone 7P
- de
تم إعادة تعيين وتم كسر الجهاز
- de
hello i need 13 p m laser software can;t dawnload
- de
hi please i need new update file remove back glass iphone laser machine thanks
- de
hi please i need update file remove black glass laser machine thanks
- de
Agregar un comentario
2 Respuestas
You save change file but you can download file from:
http://www.shenwangda.com/en/h-col-125.h...
Fue útil esta respuesta?
Puntuación 0
5 comentarios:
Hi Stad.
I did for a saved change file I messed up, and it worked great. BUT, the file for the iPhone XS MAX is not working from this download. The laser is missing the bottom corners of the phone.
Do you know how I can work around this issue? Or, is the file set specifically this way so the laser does NOT hit those lower corner sections on purpose?
- de
Hey, I don’t know if you ever found the answer you were looking for, but I found the treasure trove of files from the company. Most likely after use something got edited with the original file and it broke it. Here’s the link to the files. You want the one with 3.0.zip in the name.
- de
hi i have a problem with the laser machine is that it does not give the correct size when choosing a specific shape for a mobile device
- de
the new 3,0 from the shenwangda website is .lmf3.
i have the full 2.0 with all templates before the 3.0
contact me on smurfos76@gmail.com if still needed
- de
I have a tbk958f blue laser machine, but I could not retrieve the lost files. Can I retrieve the files?
- de
Yes I am tray so need files
Puntuación 0
Añadir tu respuesta
strelok estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 9
Ultimos 30 días: 56
Todo El Tiempo: 9,559
