Saltar al contenido principal
Model numbers JSN-L21 and JSN-L42.
Preguntas 20 Ver todo
Phone not responding, no charge indicator light.
My smartphone stopped working after i had charged it to 100% capacity overnight. The next morning i was still able to use the phone, but i noticed it stopped working after class. The battery is still fine (i checked it with a multimeter). Maybe a broken powerswich? There is no red indicator light or a charging iconon the screen (Was just replaced) while trying to charge the smartphone. Maybe a bad charging circuit?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
3 Respuestas
Paul Streck  sure could be a failed charging circuit. The very first thing that you do want to rule out is the battery. You cannot check a battery with a multimeter since it may show proper voltage but can fail under load. Replace the battery and re-evaluate.
Of course, you also want to make sure that your charger works properly as well as your charging cable.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
I am 90% shure that the battery is not the problem, because the red charging indicator light is not lighting up. The light shouldn't be that much of a load to cause battery voltage sag. My charger and cable are working properly. I personaly think that there is a problem with the mainboard power delivery since basic things like the charging indicator are not lighting up.
- de
If you know how to open the phone, try unplugging the battery and pressing the power button for 1 minute to drain any excess power in the device that may be causing this.
Puntuación 0
1 comentario:
Tried, but didn't fix it :(
- de
I have slept at night by keeping phone beside me and when I saw morning it didn't work from last 1 month
Puntuación 0
Añadir tu respuesta
Paul Streck estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 1,902
