Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La PowerShot SX200 IS de Canon es una cámara compacta de 12 megapíxeles con controles manuales, lanzada en 2009. Las características incluyen una lente gran angular, zoom de 12x y video HD de 720p.
My SD card won't lock. Help?
The SD card in my camera has stopped locking into place for no apparent reason at all. I havetried using a different SD card, so it’s a problem with the camera. It still works, because it is held down by the battery cover, but it’s a right nuisance. Can anybody help me?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
The spring mechanism on the SD card slot is broken. Canon solders it onto the primary PCB in the point and shoot cameras, so you need to repair the board or replace the entire PCB.
The problem is cost. In a lot of cases, board replacement tends to be as much as another camera (or an upgrade) so it is rarely worth doing. Because of that, you’re usually better off trying to solder a new SD slot on and hoping for the best. If that fails, time for a new camera.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Daniel Chamberlin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 19
Todo El Tiempo: 566
