Saltar al contenido principal
El Roboraptor es un robot parecido a un dinosaurio que utiliza pocos motores para moverse y reproduce audio monogrado. Lanzado en 2005, también venía con un control remoto. Tenía un botón Shift, cinco botones de animación y cinco botones de movimiento junto con un botón Demo/Roam. En 2013, se lanzó el Roboraptor X, seguido del Roboraptor Blue en 2015. Este robot pertenece a la serie Robosapien (RS) y mide aproximadamente dos pies de largo. (Agrega guías a esta página, ya que por ahora solo brinda información sobre el juguete).
Can someone fix my Roboraptor's head rotation problem?
The problem is that when the head is supposed to rotate once, it rotates three times around before stopping in the 90° position. When I press the “Rotate Head” button on the remote, it will turn 90° into the position from before, then pressing it again will make it rotate 90° again, then pressing it again will make it rotate about 180° to the original position, or 270° into the 90° position again. Pressing the opposite button will make it rotate in the same way in the other direction. This started when the batteries got low earlier last week, and the Roboraptor managed to turn its head when the motor was having trouble turning it, where it did the same thing. This usually fixed after a reboot, however. Now, rebooting it does not fix the issue, after I finished charging the AA batteries this morning. I do not know how to fix the problem. Does anybody have an answer that could help me? Thank you!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
5 comentarios:
At one point, the head twisted so far to the right, I heard a *click*, but managed to twist it 90° back into the correct angle.
- de
The batteries discharged completely and were recharged, but this did not fix the issue. I would like at least a suggestion on what might be a good fix. Anything would be appreciated. Thank you!
- de
This device has no other questions and no replies or answers. Are people having trouble posting them? Please reply, as I do not know if others can post questions, comment on them, answer them, or create guides or wikis for the Roboraptor. If there is no reply, I will assume nobody else can do anything related to this device. Thank you!
- de
@azazelo Thank you. This may be quite a helpful hint!
- de
It seems that I also did not mention that this only happened after the batteries discharged and the motors were too weak to move the head.
- de
Agregar un comentario
1 Respuesta
Hey, In my case, the issue with the head position was tilted because of a broken spinal rod. The neck contains 3 plastic rods that are nested from either side. The head of the roboraptor was always tilted to one side, and when I opened it up, I saw that one of the rods was snapped. I replaced it with a rod from another raptor I kept for parts, and then it got right.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Michael Deitz estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 30
Todo El Tiempo: 793
