Saltar al contenido principal
Número de modelo NV370. Tiene una altura de 27 pulgadas y cuenta con la tecnología de succión y dirección giratoria de Shark.
Preguntas 20 Ver todo
Roller brush doesn’t turn - Shark Lift-Away brand
I have a Shark Lift-Away, the brush has stopped turning. I have cleaned it, etc.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
2 comentarios:
My roller also stopped working. It would be nice if you could remove brush to see if there is hair wrapped around where the brush connects.
- de
@yazminkuba18603 You can remove the brush, but it's not just a matter of snapping open a couple of latches on these machines; there are like 10 screws that have to be taken out but it is doable.
Shark Navigator Roller Brush Replacement
- de
Agregar un comentario
4 Respuestas
If your Shark Navigator Lift-Away Pro vacuum’s floor roller no longer spins, see the Shark Navigator Lift-Away Pro Floor Roller is Not Spinning problem page for possible causes and solutions.
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
That instruction is basically clean it, it doesn't have an answer.
- de
Mine just doesn't work no .atter what I do
- de
have check all obvious problems but brush roll wont turn
Puntuación 0
2 comentarios:
I'm having the same issue. Is there a reset button for the beater bar(brush roller)?
- de
Mine won't even turn manually.
- de
Brand new right out of the box will not pull or push spin brush does not work.... WTF is the problem with this vacuum
Puntuación 0
1 comentario:
Take it back, why worry?
- de
It is either:
A stuck brush because of debris
A bad or broken belt
A bad switch or connector
A bad brush motor.
Puntuación 0
Añadir tu respuesta
Barbara Glosson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 19
Ultimos 30 días: 88
Todo El Tiempo: 5,542
