What can I do to stop my vacuum from turning off every 10 seconds?
The vacuum worked fine the first few times I used it, but it now turns off every couple seconds even when the battery level says it has charge.
Es esta una buena pregunta?
The battery cells have died. You need to replace the overpriced battery. It won't be covered under the warranty. :/
Fue útil esta respuesta?
I think it’s the switch. Mine is having the same problem, but the batteries are fine. When I took apart and engaged the switch manually, it worked with no problems.
I replaced the batteries but it didn't help it still slowed down and stopped in about 20-30 seconds. I'll update this post if I find a fix.
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 35
Todo El Tiempo: 2,276
