Fans are blowing at full power in sleep mode only
Dear Community,
I hope you have more ideas than me and you can help me with this :-)
Once my Macbook goes into sleep mode, either through closing the lid or by clicking on sleep on the apple menu at the top left corner, the behavior is as follows:
- After closing the lid it takes around 20 seconds until the MacBook really goes into sleep mode. You can hear that, because the first 20 seconds the fans are blowing slowly, probably to cool the cpu down before going into sleep mode.
- After this, you can hear that the fans stop and the Mac really goes into sleep mode, but right after the fans start blowing at full power and never stop (even after two days)
- The fans work perfectly fine while using the mac. Even controlling the fan speed using a dedicated sofware work perfectly fine.
Things I tried:
- SMC Reset (several times)
- PRAM Reset
- Boot into Safe mode
- Complete reinstall of the OS
- Running Hardware Diagnostic: Showed no errors
Things I noticed:
- Even if I close the lid on the user profile selection screen (right after boot, before logging on) it happens
- After the Hardware Diagnostic you can boot into a “special” safe mode, where you can only sent the diagnostic results to apple. And it happens even there.
- The instant I connect the power chord, while in sleep mode, the fans stop.
After all of this, I assume it really is a hardware issue. Do you think I can fix it myself? Or what would you do? Unfortunately the MacBook is already out of warranty.
Thanks for your support!
Thomas
Update (01/13/2020)
@vhanzl Thanks again for your help. Unfortunately cleaning did no help. Here you can find a picture:
Es esta una buena pregunta?
2 comentarios
I'd hypothesize that SMC controls fan via PWM, switching signal line between ON and OFF. When SMC itself goes to sleep (say those 20 secs after closing the lid), it leaves this signal in a default state which should be OFF but is ON instead due to some minor hardware fault. There might be big pulldown (or pullup) resistor on FET gate and due to disconnected resistor or partial breakage of the FET or dirty board surrounding these (dirt acting like resistor pulling the signal wrong way), signal defaults to ON instead. Maybe you could first try cleaning the board around the place where the fan is connected and send us photos of it if cleaning itself does not help? We might spot that FET which I imagine and hint you more what to measure or try.
- de Vaclav Hanzl
Hi Vaclav, thank you very very much for your suggestion. I will try it and get back to you once I know more :-)
- de Thomas Toffalori
