Saltar al contenido principal
La única versión wi-fi del iPad Air de Apple, número de modelo A1474. Disponible en Space Gray o Silver, incluye el procesador A7 personalizado y se envía en configuraciones de 16, 32, 64 y 128 GB.
Preguntas 20 Ver todo
iPad turns on when plugged in but wont charge
I plugged my ipad into the wall when it is on and wont charge but when I turn it off and plug it in it will power on like it detects the charger but wont charge and also not recognized on my computer
Es esta una buena pregunta?
Puntuación 0
3 comentarios
I tried 3 chargers 1 of apple 1 after market with certification and 1 with out only 1 that turns on the ipad is non certified 1 ipad dosent respond to any other cable
As far as I can tell it looks good inside the charging port
I can check with 3utools since the computer isn't recognizing the ipad
I sadly don't have USB ammeter to check
I've also tried a battery swap and it still doesn't make a diffrents
- de
Most likely the Lightning flex, I change these all the time...
- de
same thing happends to me i cant find a fix its been like this for 4 hours
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Hello Jayden. When troubleshooting charging issues, I would do the following (in order):
  • Always try another Lightning cable and charger, preferably Apple original or MFi certified units.
  • The Lightning cable 8-pin connector should be sitting flush with the housing and completely inserted. If it is not, there could be lint/dust/debris inside the port impeding a proper connection. You can clean it out with a toothpick, fine point tweezers or a dental pick. Just be careful not to damage the pins inside the Lightning Port.
  • Change the battery. The battery is the weakest link and certainly for charger related issues. It is also the easiest thing to replace. Use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows) to test the battery prior to removal. Anything less than 70% of design capacity will require replacement.
  • If the battery is in good condition, you can use a USB Ammeter to determine if the device is really drawing current when it says it's charging. If it isn't drawing current, then I would change the Lightning/Charge Port. The iPad Air has a well documented history of charging problems. Over time, it loosens within the housing and this causes the flex, at the point where it connects with the port, to crack. This repair requires some micro-soldering.
Fue útil esta respuesta?
Puntuación 5
1 comentario:
I’m having this issue. What’s cost to replace battery.
- de
Añadir tu respuesta
jayden gumb estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 14
Ultimos 30 días: 78
Todo El Tiempo: 5,695
