Color screen not working well
My LED screen is not working well my screen had broken so I replaced that but now my LED is distorted I teoes connecting the cables on the back but no luck
Es esta una buena pregunta?
Estela Villafuerte double check your work. Make sure that the ribbon abel for the screen is properly inserted. Remove it once and try to reseat it. If all of it looks okay (check the connectors for broken bend pins etc. as well) then it is possible you have a bad screen. You may have to return it and request a replacement.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 42
