Saltar al contenido principal
El VG248QE es un monitor para juegos de 24 pulgadas lanzado por Asus en enero de 2013. Funciona a 144 Hz y es compatible con Nvidia 3D Vision.
How to make it run on 12V
I’d like to connect it to my Van electric system which runs on 12V, without having to use an inverter (since it kills the battery life). Any suggestion or recomendation will be most appreciated.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
There is no other way than 110VAC to power this monitor. You could look for a monitor that has an external power adapter and coax power input.
Fue útil esta respuesta?
Puntuación 0
I know that, yes, an inverter would take more or less an extra 30 watts when running, but unless you are running the engine, it doesn’t matter which way you power the monitor, the monitor’s watts/consumption will be the same. Car/Van batteries are not designed to be drained in this fashion, with the engine off. They will be ruined if they are deep cycled. Now, if you have deep cycle batteries or are running the engine, then an inverter is the way to go because battery life will not suffer.
Puntuación 0
Añadir tu respuesta
Gon Arada estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 281
