5 beeps and 5 beeps.
I searched and found out that the system board has a problem when there 5 beeps and then 5 beeps. How do you fix the system board?
Es esta una buena pregunta?
Generally, you cannot fix motherboards due to the soldered components on the motherboard. However, you can replace the motherboard even if it is a laptop. First make sure to note what screws are holding the bottom cover in place and use the required tools. Also, make sure that you are 100% sure that it is actually the motherboard even if the information provided to you is highly reputable.
Generously,
Richard Smith
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 37
Todo El Tiempo: 3,648
