No cable charging, only wireless charging after USB shortcut
Hello,
My Samsung Galaxy S9 is not charging thu cable after I had a little shortcut on a usb cable.
When the phone is off and I connect charging cable it will show me the exclamation mark inside the battery sign and will not charge. I tried to leave it even for an hour and still the same issue.
Phone charges thru the Wireless charging pad but very slowly. When I use it, it will loose the charge very quickly straight down to 1% !
It gets quite hot even when not used. I have changed the charging USB port pcb and still the same issue.
I do not know where to go next. Please advice.
Thank you very much.
Best regards,
Zbigniew
Es esta una buena pregunta?
