Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Samsung Galaxy Ace II X cuenta con un procesador de 1 GHz, una cámara de 5MP y una pantalla TFT de 800x480.
How to repair water damage phone?
Hi,
A friend gave is old phone because it not working. After dissembling it I can clearly see that it had been water damage because of the water indicator. It a Galaxy Ace II X. I tried cleaning it with dome alcohol and bought a new battery. After pressing on the power button a can only hear sone crackling coming from the earphone speaker. I tried plugging into a a computer it not detected. Do what should I tried now ?
Huge thanks for the help.
Update (12/22/2019)
Thanks for the answer,
I tried to totally submerge the motherboard in alcohol but it still not working. I search for anything that look bad but it doesn’t seem like there any corrosion on the electronic. I took a picture of it. Huge thanks for the help.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
This is a hard question to respond, because many things can have liquid damage inside, but this is my personal rule:
“Inspect for liquid damage and corrosion, wherever is bad or looks bad needs to cleaned be replaced, if liquid touched the motherboard/circuit board, the same rule wherever is bad or looks bad needs to be cleaned or replaced.”
Fue útil esta respuesta?
Puntuación 0
It looks very hard to fix it on your own. You may try sending it to a pro or a repair center if it is really important for you.
Puntuación 0
Añadir tu respuesta
Jni Turbis estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 237
