Saltar al contenido principal
The Dell 1710n is an office laser printer released in 2011.
Preguntas 7 Ver todo
How to remove white 'scuff'marks on print jobs?
Had no problem until this week - my 1710 printer is not printing clearly, there are scuff marks that repeat in 'white cloud' shapes down the page in regular intervals. I have pulled out the printer catridge etc and have wiped out excess toner internally via the front panel. Is this problem caused by a piece of paper stuck on the rollers ?? The dell toner cartridge is hardly used, as new.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
This is usually caused by a scratched drum. If not, then you exposed it to too much light or you exposed it to light or touched it.
Usually light damage is permanent. You probably need a drum at that point. However, if you let it sit in the printer and not use it, it may recover. It probably won't, but it does have a chance. It's better then assuming a drum dead and that's like 50-60.00 to replace dead. Scratches are always cases a drum rebuild or a new drum is required.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Johanna estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 1,097
