Why is my car starting hard n how do I fix
My car has hard time starting every time I start it after I replaced starter plugs wires camshaft and crankshaft sensors
Es esta una buena pregunta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 55
The first few things you check for is Spark, Fuel and Compression, if you have spark, normally the crank and cam sensors are good along with any ignition items, plugs, wires, coil, ignitor. Hard to start is typically related to fuel pressure, if you cycle your key on a few times before trying to start, does it start up better?
- de Duane Donaldson
