Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
iPhone 6s shows no service
just today my iphone 6s shows no service, this is after i notice that the battery start to swollen. Any idea what could have cause this, and how to fix it? Is it an antenna that i need to replace?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario
i had a freedompop AT&T sim card, which only has data access, when i put it in it shows service. It does not get service if i put in a AT&T or Verizon sim card.
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
I guess it might be the antenna, SIM slot or something severe, like damaged motherboard. Or it could be something with the SIM card itself.
Try to remove SIM card from the phone and then put it back in. Does it go from “No SIM” to “No Service”? Can you also try a different SIM card?
Fue útil esta respuesta?
Puntuación 1
8 comentarios:
i have tried 2 sim cards, they go from no sim -> searching -> no service.
- de
Got it. You should check antenna cable then. I doubt that swollen battery would cause any motherboard issues, so that’s probably the reason behind “No Service” sign.
- de
i saw on youtube there is there wifi antenna cable, thats by the speaker. Is there a antenna cable for the cellular antenna as well?
- de
Yep. It’s at the left top side of the motherboard. There’s iFixit guide on how to replace it.
- de
reseat the cable, still no go. does searching, then no service.
- de
Mostrar 3 comentarios más
If you still ahve time than show it at an Apple and Find out the cause of the problem from them. Once you know the problem, post it here. Maybe we could help you.
Actually, you have given very vague information about your problem. Getting more information about the problem you are facing will helk us to help you in a better way.
Puntuación 0
could be baseband is giving you issue this might get repair by micro soldering my best suggestion is take it to a professional with micro soldering ( iPad Rehab) and they will fix the issue
Puntuación 0
1 comentario:
what are the step to check if the baseband is the issue?
- de
Añadir tu respuesta
Charles estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 137
