How do you remove Sleeve Spacing Assembly?
how do you remove the metal from the Sleeve Spacing Assembly ? do you need a special pulley?
Es esta una buena pregunta?
You could probably use a bearing puller tool? Or clamp some underneath it such that it's not gripping the axle but is providing pressure to the lip of the sleeve, then on a hard surface use a hammer to hit the axle.
Damage in any case here could compromise the quality and safety of the repair.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 188
