Saltar al contenido principal
Lanzado en marzo de 2017, identificado por el número de modelo SM-J727
J7 Crown Black Screen
I have a J7 Crown S767VL that has no screen display it stays black phone is still powered on and when I try to hard reset it doesn't fix the issue I have tried to power off by holding power + volume down button for 20+ seconds and after about 15 seconds of holding buttons it vibrates every 1-1.5 seconds and does not power off. I have been attempting to factory reset with black screen with no luck and have exhausted my options available online. Please give me suggestion(s) on what I can do it is a straight talk phone.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
Agregar un comentario
1 Respuesta
It sounds like an LCD fault. Has the phone been dropped in water or dropped on a hard surface?
Fue útil esta respuesta?
Puntuación 0
12 comentarios:
I do not believe it has gotten wet or dropped, it is in pretty pristine condition as far as I can tell I was thinking it was a corrupted firmware issue
- de
You will need a new LCD if you haven taken phones apart then you can replace the screen yourself or take it to a repair shop. It will be a whole lot cheaper replacing it yourself if you do that go here https://www.amazon.com/Replacement-Digit...
- de
Is there a way to try to perform a factory reset without the ability to boot in recovery mode and being unable to do it through settings?
- de
Hope this helps
- de
Yes if you have a computer
- de
Mostrar 7 comentarios más
Añadir tu respuesta
Corbin Dallas estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 1,641
