Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Modelo A1625. Revisión de 2015 del reproductor multimedia de Apple, equipado con un procesador A8 y 2 GB de RAM.
Replacing the wifi chip in my Apple TV 4
Hi,
My Apple TV 4 has a defective bluetooth/wifi chip. So I found one on eBay, a 339S00045 chip, which seems to be the same as in the ipad mini and pro. I took my apple tv apart, but the chip doesn’t seem to be that easy to replace. Is that something that is even possible at this point?
Regards,
Pieltre
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Sadly this is a BGA chip which really needs a proper rework station to fix.
Basically, after you carefully remove the old chip you would clean the old solder off clean the board and then using a mask and the correct sized solder balls layout the field and then reflow the chip back on.
Given the cost of the needed equipment and sundries. I think it will be cheaper just getting a new Apple TV ;-{
Fue útil esta respuesta?
Puntuación 1
You cannot replace the WiFi chip as its paired, tried already. no way to get the device into DFU to restore either
Puntuación 0
Añadir tu respuesta
Jean Maxime Lachance estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 22
Todo El Tiempo: 1,003
