Saltar al contenido principal
Find repair information on the second generation Toyota Tacoma.
Preguntas 20 Ver todo
4wD indicator and 4 low lights on
Hello , 2005 Tacoma 4WD light and 4Lo lights blinking when ignition on . 4WD is in op. Plug in snap on scanner to data link port , and everything works fine , lights go out . Unplug scanner and lights flash immedialty
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Either your front add motor is bad or the 4wd selector switch is blown.
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
I’ll check the switch when I get home , it’s just does t make any sense that everything works as designed when I plug my scanner in , then quits when I unplug it , I’ll check the switch and the park neutral signal today
- de
What was the fix? I am having the same issue right now...
- de
Añadir tu respuesta
Sean baldwin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 3,187
