Why does the brush stop spinning
model 6984a1 the brush stops spining like it is to close to carpet
Es esta una buena pregunta?
Solution 1:
Drive Belt
Inspect the belt to see if it is broken, stretched out, or out of place. If the drive belt is broken or stretched out, replace it.
Genuine OEM Part # 75614
Solution 2:
Brushroll
If the brushroll is sticking, it will cause too much friction and put too much strain on the belt. Remove the brushroll and clean all hair, string, and lint from the brushroll bearings. If the vacuum cleaner brush still doesn’t spin after you clean the brushroll, consider replacing the brushroll.
Genuine OEM Part # 61699-1
Fue útil esta respuesta?
Ultimas 24 horas: 4
Ultimos 7 días: 12
Ultimos 30 días: 44
Todo El Tiempo: 5,084
