Motor shuts off at high speed
When i move the lever to #8 and #10 the motor shuts off. I normally don’t mix at high speed but it was by chance i moved the lever to those positions and discovered the problem. Any assistance would be great. Thank you.
Es esta una buena pregunta?
Quoted from the following link:
"If your mixer is only working on certain speeds, you might need to replace your circuit board. Don't worry, follow this guide on how to replace the circuit board."
KitchenAid Classic Mixer K45SSWH Circuit Board Replacement
Probably a good starting point if you are thinking of doing the repairs yourself. Just make sure you unplug the unit from the AC wall receptacle before undertaking any repairs.
- de prop man
