Why 031006 error code on my screen
How to fix code error 031006
Es esta una buena pregunta?
Epson error code 031008 generally occurs due to improper insertion of the printhead or ink cartridges. Accumulation of dust on these two printercomponents can cause this error code to appear. It occurs suddenly in between an ongoing printing session without giving any prior intimation.
UPDATE
Contact points
Installation
Possible Causes:
Things to try:
Fue útil esta respuesta?
how about error code 031004 on epson L3110 ? Thanks in advance.
Renz read my answer
This is for error 031008 not 031006
Please help me fix error 031006 on wf 7710 printer.
Here is the correect answer.
When moist, such as ink, creates a short circuit between two contact points in the printhead of the ribbon cable that connects it to the main board, then a small fuse on the mainboard blows. The error code the printer gives is 031006. The fuse on the mainboard is marked with F1 or F301 or something similiar. It is small!! I can’t tell you where it’s located as that is different for every different mainboard version.
Are you confident with a screwdriver and a soldering iron? Then you can do this and save yourself a $100 new mainboard. Take the covers off your printer, disconnect all cables off the mainboard, take the mainboard out, spot fuse F301 or similar and measure its continuity with a multimeter. If the meter does not beep: bingo. Replace the fuse, assemble everything, your printer works again.
If you found the fuse to be properly working, then don’t touch it and check all ribbon cable connections and clean all contact points between printhead and mainboard instead. https://www.youtube.com/watch?v=VoxwMqZN...
This is best answer by far on this forum. Another forum poster Kevin BCH says it could be fuses F1, F2, F3 so check them all!!
031006
MEANING="Head fuse broken error"
DESCRIPTION="- Printhead failure"
Imexindo... so what we have to do to fix it?
I have the same error code 031006. How do I fix this? I heard on Youtube Epson does not sell replacement heads. I also found the same printerhead, an after market printerhead on AliExpress.
epson error 031006
Dear Sir/Madam
My Epson Printer Error code 031006 , WF-7715?
@manolosolis the main board requires replacement. The fuse labeled F301 on it has failed.
Ok I think I solved this issue on two WF-7710 units with cg36 boards. The fuse was not F1 that failed. It was F2 on both machines. For anyone with a bad board caused by a bad print head make sure you check all three fuses on this board mine happened to be F2! I hope this helps someone.
Oh and if this happens it’s because of your print head, don’t reuse it! Get a new one.
What type of fuse rating did you use?
hi what mean error code 031006 epson 7720
and epson 7710
The 031006 is referring to a bad fuse on the main board. This is typically caused by a short across the print head ribbon connection due to ink/moisture intrusion.
The fuse is labeled F301 on the board and is not user serviceable; it will require the main board be replaced.
I would not say it is required to replace the mainboard. I would say for most printer users it's not possible to repair it and they would have to bring the printer to an Epson service center. A new mainboard is an expensive way to solve a $1 broken component problem!
I have a EPSON ET 4750 cleaned ink ports with Alcohol yesterday printer worked fine then kept telling me paper jam . Now I have error code scanner error code031006 to turn off. Have done this numerous times with no luck. Can this be fixed?
You Need to replace the fuse and check/replace the strap cable to the print head.
Hello everyone, my name is Wael Al-Massive. I have an Epson 7710 printer. When I turn it on, I get a malfunction code 033001 on the screen. Please help me so that I can fix it. Thank you very much
If your printer's status displays "Printer in error state," there may be a problem with the printer itself.
Make sure the printer is turned on and connected to your PC by Wi-Fi or cable. Check it for low paper or ink, and be sure the cover isn't open and the paper isn't jammed.
Greetings,
Peter
This is an answer that does not add anything. Jammed paper, sure.
You give a generic answer that is not applicable to this range of printers and certainly not to this particular error code.
This error indicates that a fuse on the main board has blown. You can replace it is you are good with a soldering iron. Read my answer above for the details, thank you.
ive got error code 031006 today on my xp15000. anyone know the problem is?
Ultimas 24 horas: 38
Ultimos 7 días: 216
Ultimos 30 días: 1,027
Todo El Tiempo: 83,349
14 comentarios
Have you check your Owner's Manual? How about https://epson.com/Support/sl/s. You will have to supply your printer model # there though, which is also a good idea to provide when asking in a help forum as all printers are not the same.
- de prop man
@alchain6003 what model is your printer and when did the error code show up? Anything done to or happening to your printer prior to?
- de oldturkey03
Epson wf 7710 yes I refilled my ciss with ink primed put cartridge back when I turned on this error code wont go away
- de alchain6003
لدي طابعة ابسون 7710 كانت الفوهات مسدوده ففتحتها بمنضف وستعملت الطابعة وكان ادائها جيد وبعد يوم قمت بتشغيلها وضهرت لدي على شاشه الطابعة (خطأ في الطابعة اعد تشغيل الطابعة واذا ضهرت الحاله نفسها راجع الوثائق المتوفره لديك وبالاسف مكتوب هذا الرقم 031006) ممكن مساعده لاني حاولت اصلاحها ولم استطيع
- de MOSES AL-SULEMIN
The following information is being given regarding Epson error code 031008 is good to know about. I have sorted out this issue with the valuable guidelines provided. I have another small query regarding the error code 0x5. I am facing a huge issue regarding scanning. I have followed out the following steps as informed by the helpdesk
Fix Epson WF 3640 ADF Not Working. It is not working out. Suggest what to do for the solution.
- de Shanon Smith
Mostrar 9 comentarios más
