Doesnt turn on. Fan makes weird noice
I have a MacBook Air 13” early 2015 that doesn’t want to turn on. By that i mean absolutely nothing is happening when you push the “On” button. The fan doesn’t start spinning, it doesn’t even show sign of trying to move. But every time i push the “on” button you can hear small beep noise from the fan. Sounds like it’s trying to start but fails instantly.
I have already checked the battery, charging port and charger and found nothing wrong. I’ve also checked the cable going from the charging board to the main board and that also looked fine.
My guess is that this is board related, but i am not so experienced with that and i,m looking for pointers for where i should start looking.
Thanks in advance!
Es esta una buena pregunta?
2 comentarios
Let's try this, disconnect the charger and battery. Press the power button for a good minute to discharge the system, now with the battery still disconnected plug in the MagSafe charger. Does the system spontaneously start? If not, what is the color of the MagSafe?
- de Dan
Thank you for your answer @danj.
I tried it just now and nothing happened. I tried several times to.
The first time there was no light at all. The second time there was no light, then it turned green before almost immediately turned red/orange. The third time there was no light, then it turned red before slowly fading away.
- de Total Repairs AS
