Saltar al contenido principal
La actualización de abril de 2014 del MacBook Air de 13" de Apple presenta procesadores i5 e i7 de doble núcleo actualizados, además de un rendimiento ligeramente mayor de la batería.
Preguntas 313 Ver todo
Help with blown display socket pins— is this repairable?
Hey y'all,
I've got an interesting situation with an Early 2014 MacBook Air.
This device had soup spilled on it and was not powered off immediately. They attempted to drain the soup out of the bottom right corner where the display connector was, and as a result, the backlight no longer works. (it is worth mentioning the screen still works, I just used a flashlight to test)
Upon inspection, I discovered the display connector on the logic board has 6 blackened pins and 4 completely blown ones. Not only do I not have the equipment to repair this, it's also far beyond my “pay grade,” so I was considering taking it to a local repair shop with microsoldering equipment and seeing what they could do. What I’d like to know is it this is even something that can be fixed without a new logic board, because if not, I'll just buy a new board.
Here are several different pictures of said socket.
(hosted on Imgur because iFixit’s media uploader broke)
Thanks in advance!
Edit: Clarified a few things.
Es esta una buena pregunta?
Puntuación 1
2 comentarios
You might consider just replacing the logic board. But as you have more than that here it might not be cost effective.
- de
@danj If nobody can perform this repair that's what I'll do, but otherwise I'm hopeful someone can fix it for less than $250. However it is also possible there are other issues related to the logic board, which is why I'm skeptical about this whole situation.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
@reedcrosby can it be done? Yes, but it will require microsoldering skills. A good cleaning of the board after removing it and then replacing the connector should repair this. At least it will get you to a point of ensuring that nothing else has failed. You do want to check on microsoldering specialist to replace it. Not terribly complicated but because of the size of the connector etc. you will need to have the right tools and skills. Depending on your geographical location there may be experts on here that could do this for you.
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
This is pretty much confirming what I thought. I don't have the equipment or expertise for microsoldering, or soldering at all for that matter. I'll see if there's anyone that specializes in it near me. Do you have an idea of a ballpark cost for this as opposed to replacing the logic board?
- de
@reedcrosby hard to say since I do not know where you're located and what the going shop rate is in your area. At least you can try to save some money by removing the logic board and sending it off for repair.
- de
@oldturkey03 It look's like I'll be sending it off or buying a new one, some shops have refused because of liquid damage, and others gave horrible quotes in the $250+ range.
- de
Respuesta Más Útil
It quite possibly could, but several jumpers would have to be ran, and it wouldn’t be that reliable with several next to each other. If it can be, the cost may well be more than a replacement due to the extensive work that will have to be done in that small area.
Puntuación 2
1 comentario:
That's along the lines of what I was thinking. Also, I don't have the tools required to even think of doing soldering that small, because I'm not sure the pictures show it well, but these pins are really small.
- de
Añadir tu respuesta
Reed Crosby estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 15
Todo El Tiempo: 157
