Saltar al contenido principal
El Super Nintendo Entertainment System (SNES), o simplemente Super Nintendo, es una consola de juegos de 16 bits lanzada por Nintendo en 1990. Super Nintendo fue uno de los más vendidos de su tiempo y todavía tiene una gran base de fans en la actualidad.
Preguntas 103 Ver todo
Why do I have a black screen and why does my TV make a buzzing noise?
my Super Nintendo is receiving power(AKA the light is on.) but i get a black screen and i can hear a small buzz coming from the speakers. has my motherboard gone bad or is it something else?
Es esta una buena pregunta?
Puntuación 1
4 comentarios
From what I have been reading it would appear that the “72 Pin Connector” is a common source for problems. Might want to check out (or similar) the following:
http://classicgamesblog.com/2011/03/05/h...
And while you have it apart, do a visual for for bulging caps, burn marks, dry or cracked solder joints, exploded components etc
- de
could it be a short in the power cable? i laid it length wise and i got a little black screen. at least briefly.
- de
@propman I had to shove a piece of paper in between the cartridge and the side wall of the slot...
- de
@Jordan Fryman Which I suspect indicates the contacts are intermittent. Suggest you try what is recommended regarding the cleaning and readjust any pins that need realigning on the connector.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
the cartridges were dirty "(even though i already cleaned them :| ) and the pins on the console itself were pushed outward. Works perfectly now… but i also have a problem with my N64 too
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Jordan Fryman estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 28
Todo El Tiempo: 2,925
