Saltar al contenido principal
Guías de reparación, manuales y ayuda para la resolución de problemas de Lenovo N23 Chromebook. Accede a todo lo que necesitas para reparar tu Lenovo N23 Chromebook tú mismo.
Preguntas 9 Ver todo
Need help Unmanaging a chromebook
I bought a used chromebook off eBay and it is enrolled in some school thing i tryed to access dev mode by removing battery and plugging ac cord in multiple times but it still says admin blocked. And I don’t know if theres anyway to reset the bios can any of you help me
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
To Wipe your Chromebook follow these steps
  1. Turn off the Chromebook.
  2. Press Esc++Power.
A yellow exclamation point (!) or "Please insert a recovery USB stick" is displayed.
  1. Press Ctrl+D to begin Developer mode, then press Enter.
  2. Press Space, then press Enter.
The Chromebook deletes its local data, returning to its initial state. This can take approximately 40 minutes.
Note: ​If Forced re-enrollment is enabled for the device, you'll see a note that Developer mode is blocked. This shortens the wipe process, and still allows for re-enrollment when the device automatically restarts in Verified mode.
  1. When the transition completes, press the space bar, then press Enter to return to Verified mode.
  2. Enroll the Chromebook before signing in to it.
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
That’s the problem I’m trying to change the forced enrollment by changing the rw_vpd in dev mode but it’s blocked so what can I do
- de
Have the same problem, bought a set on bankruptcy auction. They are locked and the old company is no more. 😟
- de
Añadir tu respuesta
Caleb estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 870
