Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Samsung Gear S3 Frontier (SM-R760 y SM-R765) es un reloj inteligente de alta gama diseñado para reducir la necesidad de un móvil. Lanzado en noviembre de 2016, el dispositivo tiene una pantalla de 1.3", un procesador Exynos de doble núcleo y un sistema operativo Tizen personalizado.
Vibration motor does not work anymored after the baterry replacement
After the replacement of the battery the vibration motor stopped working.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
Well unfortunately this happened to me as well just replaced battery then vibration stopped working. I looked at it and it was my fault when i was pulling up the main board i must have hit one of the components that power the vibra motor the components is so small about the size of a grain of salt and i am unable and not cordinated well enough to solder somthing that small so i will have to go without vibration but the location of the components on the board is so close to the edge it is my guess the same happened to yours
- de
Agregar un comentario
1 Respuesta
Did you repair it yourself or did a shop do it for you?
The component is propably damaged and needs to be replaced,
If the shop repaired it for you they should replace the broken part.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
I did it myself based on the instructions posted here. Normally I pay attention to instructions and until now I did not break running components when fixing other equipments.
What would help me is a how-to for the vibration motor in order to check if maybe its contacts got loose, as the vibration was working ok before changing the battery.
- de
Añadir tu respuesta
corneliusss estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 45
Todo El Tiempo: 838
