blue light in charger goes out when I plug it in, no power,
I went to plug in charger, the blue light goes out when I connect it to the laptop, no power, no life, I have changed the charger, same problem,
Es esta una buena pregunta?
Try a Different battery and go from there, If battery is bad easy win if that does not work you will have to take a look at the display.
Fue útil esta respuesta?
Thanks for the reply Cale E,
I removed the battery and pluged laptop in directly to the power pack, as it should run of either the battery or the mains, but still the light still goes off, so its not the battery and there is no display to read, the blue light going off is the only sign of life until its pluged in.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 260
