Saltar al contenido principal
Lanzado en Septiembre 16, 2016. Modelos 1660, 1778. Disponible en GSM o CDMA / 32, 128, o 256 GB / Oro Rosa, Oro, Plata, Negro Mate y Negro Brillante.
Preguntas 1366 Ver todo
iPhone 7 Plus stop charging at 3% after replacing new battery.
My iPhone 7 Plus battery just got replaced with the new one. I forgot to put ‘sticker’ to prevent the battery from moving. after few months the old battery stoped working, I even cannot charge it at all.
After that I replaced it with a new one. It stop charging at 3%.
I opened battery setting, it didnt show at all about battery capacity.
And then I also tried 3uTools, and I cant read the capacity too.
Anyone have a solution?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
There are some tiny components surrounding the battery connector. One of them allows the battery charge state to communicate with the CPU/Charge Circuit. It’s not uncommon to accidentally dislodge components when disconnecting the battery and this is a typical “pry damage” symptom.
Look for R2201 in the image below.
Fue útil esta respuesta?
Puntuación 3
4 comentarios:
How should I fix this?
Are you suggesting me to buy a new dock connector replacement?
- de
No, you need to determine if the highlighted component is still there. If it's missing, it must be replaced which would require a micro-soldering repair.
- de
Hi, I didnt quite understand what is actually "battery connector". I looked at the battery connector on the flex cable and in the motherboard, on my eyes the diagram given is not matching with the one I see. SO maybe I looked at the wrong one
- de
FYI: I got a replacement batt, now it charges only till 13%
and then it wont charge againt till it droped 1% and the phone restart by itself
- de
Have you tried other new battery? maybe the battery you replaced was faulty.
Puntuación 0
2 comentarios:
No, I havent. I will send it back to the seller today. I hope its the battery
- de
Just try to test your old battery if that charge more than the percent you need, if that goes up means you got a faulty batt.
- de
Añadir tu respuesta
Henka Gonzalez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 317
