Saltar al contenido principal
El Hp Notebook 15-ba018ds es un portátil con pantalla táctil equipado con el sistema operativo Windows 10. Mide 16 x 10 x 3 pulgadas cuando está cerrado y pesa 4.83 libras.
Can't tun-on. I can't turn-on my laptop. it's not the power.
can you help me please, my laptop not turn-on there are 3months ago. I check the serial on HP and I see STATUT: EXPIRED. whats wrong with my laptop and what I can do to turn-on ?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
Hi Farid
What issues are you experiencing?
no power or response when pressing the power button?
had you checked on your power adapter if it is giving out correct voltages?
- de
Agregar un comentario
1 Respuesta
Once your build reaches the license expiration date, your computer will automatically reboot approximately every 3 hours. As a result of this, any unsaved data or files you may be working on, will be lost.
The computer will no longer boot, 2 weeks after the license has expired. After the expiration date is crossed, when you start your computer, you will see a Recovery message – Your PC/Device needs to be repaired message. You will not be able to log in to your computer. In this case, you will have to download the ISO file from another computer and then transfer the ISO file to some installation media. Once you have done this, you will have to boot the computer from the installation media to install the latest build of Windows 10.
You should always backup all your data and check your Windows Update to see if any new build or upgrades are available.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Farid Sanou estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 100
