Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Repair guides and support for random-access memory storage for PC and Mac computers
Preguntas 22 Ver todo
My pc doesn’t recognize my ram
I tried using different locations but none work with ether stick.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Have you checked that the RAM Module is compatible with the PC that you are using? If you have, then inspect the physical RAM Module to make sure that there is no damage to any of the pins. Also check the bays that you are inserting the RAM into as these might also be damaged. If you have done all of these and there are no issues, check the BIOS to see if the RAM is actually being picked up as installed.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Isaac Worsencroft estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 19
