Saltar al contenido principal
Guías para la versión Wi-Fi del iPad Mini 4: modelo A1538. Anunciado el 9 de septiembre de 2015, el iPad Mini 4 es el sucesor del iPad Mini 3.
Preguntas 97 Ver todo
Can u identify this Ipad mini 4 component above the battery connector?
Hi All, while replacing the wifi IC over the weekend on this ipad mini 4 (wifi) I accidentally blew a component off the board with my hot air.
The component sits right above the battery connector and I believe it had a “TC” or “TN” written on it.
Fortunately, I did take a picture of the area pre-accident.
I also attach a picture of the pins from a schematic viewer.
I’m thinking it’s probably a TCM0605 filter choke, but any input would be much appreciated.
THanks a bunch!
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
It’s a three terminal device which would exclude a filter choke.
It is a MOSFET (transistor) and it is configured similarly to Q8900 on the iPad Air 2. Unless you have a donor board, I would simply order the Air 2 version (CEDM7001) and install it.
Fue útil esta respuesta?
Puntuación 3
1 comentario:
Thanks a bunch Minho!
- de
Añadir tu respuesta
W1ngl3t estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 398
