Saltar al contenido principal
Información y guías de reparación del iPhone 8 que salió a la venta el 22 de septiembre de 2017. Modelo: A1863, A1905
Preguntas 874 Ver todo
Battery gauge stuck to 100 %
Hello
i have got an iphone 8 with broken screen and battery reported as « service ». I don’t know the history of the phone. I changed screen but before this i couldn’t turn off the phone since i couldn’t slide on top of damaged screen. I notice that the battery even in a poor condition (bad looking) was suite good enough to power the phone more than 5 days (the delay i got the new screen) without being exhausted . When i replace screen and battery, i observed that battery charge was quite slow. After one night it was charged at 100 %. And since it is stuck to 100% !!! Nothing changes , i found an infinite battery!!! This is quite painful to be blind on battery remaining capacity. When i charged it even with 100 % , some current is consumed (proportionnally to the previous usage of the phone).
with the old battery i can’t charge it more than 37 %.
do you thing it from the bsttery or from main board. (The main board doesn’t look to be a virgin board)
thank you
Es esta una buena pregunta?
Puntuación 0
1 comentario
Hello meanwhile i received a second battery from my supplier: this one shows a normal rate of discharge… but it is mentionned : service and no max capacity is available. I am waiting for new batteries to conclude.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
This is not uncommon with aftermarket batteries. Some of them don’t communicate properly with iOS, probably because they have lesser quality Gas Gauge IC’s in them. As you said, contact your vendor and see if they can send you another battery.
Fue útil esta respuesta?
Puntuación 2
Respuesta Más Útil
Plug into a Mac with Coconut Battery installed on it to ascertain the actual state of the battery.
https://www.coconut-flavour.com/coconutb...
Puntuación 2
1 comentario:
Hi : tested with coconut and results are the same as with iPhone : 100 % capacity and 100 % charge after 24h without charging. Yesterday i made a test with a continuous play of a youtube movie: after 4 hours (with 100 % on the gauge), the phone shut down out of power... my battery is not magic. I don’t know what to conclude.. My battery provider will send a new one,
I keep you in touch
- de
Añadir tu respuesta
philippe estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 348
