Saltar al contenido principal
Released January 2016, Identified by model number BDP-S3700
Preguntas 11 Ver todo
Is it possible to open drawer if player won't power on?
player was damaged due to electrical problem.
Common solution given by Sony and others does does solve power on problem.
It’s dead.
Is it possible to open the drawer without destroying the disc that was inside when the player died?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
Usually you have to take the cover off and remove the dvd player so you can slide the tray out. It only takes a couple of minutes.
Fue útil esta respuesta?
Puntuación 3
Every disc-playing device has a small hole on the front side. This hole is for powerless ejecting the disc in case of a powerfailure. Have a look at the tray and put a needle, nail or something else thin in the hole and press on it. The tray will open and release the disc.
Puntuación 1
2 comentarios:
paper clip preferred.
- de
@ruggb A professional paperclip is the better tool for sure ;-) 👍🏻
- de
Añadir tu respuesta
Calvin Hilton estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 215
