Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Versión renovada del iPhone 3G con velocidades de procesamiento más rápidas. La reparación de este dispositivo es similar a la 3G y requiere destornilladores simples y herramientas de palanca. Modelo A1303 / 16 o 32 GB de capacidad / respaldo de plástico negro o blanco.
Home Button Very Weird Problem :@
Hi, I have restored my iPhone 3Gs using DFU mode and the home button is working fine (also done a soft reset and the button works fine), but now when I use the phone properly in the iOS the home button does not work at all, so the home button only works when doing restores in DFU and soft resets, rather strange.
When doing restarts or putting the phone in DFU I never had the two prongs connected to the charge dock, is there a different circuit for restarts and DFU modes?
any ideas what it could be?
Thanks Chris
iOS 4.3.3
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Turn iPhone off, and carefully reseat Flex Cable #4 (the Dock Connector Flex Cable). Probably the right most Flex pins are not seated all the way down to make contact with the Logic Board Connector. Seat it down all the way.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thanks for the help, still no success, I tried removing cable 4 from the logic/b, and then soft resetting to see if the home button still worked and it did, do you know are there two different connections to the logic/b one for system (soft reset/DFU and one for phone function
Thanks Chris
- de
I am also having the same problem. It is very frustrating and I cannot figure it out...also, volume up botton does not work but volume down button does. What could be the problem here?
Puntuación 0
Añadir tu respuesta
Chris Moss estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 449
