How to replace old HD
hi- I want to upgrade the hard drives of some 4th generation ipods I have of different Gb's.I've seen some information on the web about it which is not clear.I want to upgrade them with an Micro SD Universal Flash TF Memory Cards HC Class 10 and want to use CF Compact Flash Card To 1.8" ZIF/CE HDD Adapter For iPod 5G 6G Toshiba CE Video and than put the micro cards in an sd adaptor card and place this in a Extreme CF CompactFlash Card Adapter SD SDXC SDHC WIFI SD Type I CF up to 128GB. The way I think I understand it is if it is going in a 30gb ipod-than the number of partitions should be along the lines of 30GB each? I have both a mac and a pc-and am unsure the way I would need to formatt the new micro card-like mac journelled etc as the info I have read is confusing about this? I am also not sure if the above micro card would only work with a flash (usa) type adaptor which are a lot more expensive? I just wondered if you could give me some advice about this as the information on the web is very unclear/confusing how to do it? thanks
rich
Es esta una buena pregunta?
i realise the flash card adaptor I have may only go up to 128gb as that is what it says on the advert i geuss anything bigger than that and i would need the more expensive flash thing which I have seen advertised from the U S of A!
- de Richard
