Saltar al contenido principal
El iPhone 5c de Apple fue anunciado el 10 de septiembre de 2013. La reparación de este dispositivo es similar a los modelos anteriores, y requiere destornilladores y herramientas de entrometimiento. Disponible como GSM o CDMA / 8, 16, 32 GB / Blanco, Rosa, Amarillo, Azul y Verde
Preguntas 1234 Ver todo
When iPhone 5c is turned on no image, when pressed, it works~
Hi,
About a month ago I purchased some parts to rebuild my old iPhone 5c, it had all the necessary parts except for the battery and the logic board, today I have finally received the last important piece, the battery, though when I was reassembling the phone the image on the screen suddenly disappeared like it burnt out. I tried several times reconnecting the screen but any attempt to use the phone rendered it turn the backlight on. However, after some “research” I was already thinking that maybe I somehow shorted out the logic board and that’s why everything was working fine except for the screen. At some point I was already thinking about reassembling the phone just to throw it away afterwards, but instead i pressed the screen and the image reappeared again and I was able to use touch screen except I had to press the higher part (well, where the flex cables are) of the screen in order to keep the image intact.
I don’t know what to do, Do you think that the problem is in the LCD itself or the problem is in the logic board?
Please I need some advice)
thanks in advance
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
its either poorly connected screen to logic board(try reseating the connectors) or a bad screen, I wouldn't have thought it was anything worse than this.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Ali Sadykov estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 33
